Truck engine block heater
  • Truck engine block heater
    Looking for some insight, I just purchased a used 2016 Ford F150 with the 3.5 liter ecoboost, twin turbos. It has a factory installed engine block heater ( I know many have been recalled, I'm taking it to a ford dealer tomorrow). I have never owned a vehicle with a block heater. I live in NJ, so my winter mornings are typically between 20-35 degrees. Aside from the heat coming on faster, is there any significant benefit to the engine from using the heater? I basically have a 7 minute drive on some back roads before I get to the highway. Wondering if the warmed oil will really save any significant wear and tear? Thanks.
    I can't comment on block heaters, but I'm a firm believer in letting an engine warm up. I just moved and just my drive from 30 minutes to five and without warming up my engine it doesn't reach full operating temperature so I use the remote start to get it warmed up before going to work. Putting a cold engine under stress is a killer and I dont' get on the gas if the engine is cold and my last two trucks have made it to 230k miles without any major engine issues...but I drive GM products. [][8D][][]
      I lived in Lake Tahoe, 7000' elevation with a couple winters that went up to 22 feet of snow. Yes, block heaters are a great benefit in getting the engine started with oil circulation versus a sticky globulous goo trying to circulate through the oiling system. The friction and wear and tear on bearings without adequate oil flow is a killer.
      ALL my vehicles in the mountains had block heaters. In the old days, my dad would set a 60w light bulb and turn it on next to the block of our International, just to get it to start in the mornings...
        If you are training and exercising to keep your body in shape, Then you definitely should learn caffeine free pre workout and take some in your training session.
