Shed size?
  • Shed size?
    I need a shed or a building. Bigger the better is the obvious response but Im curious what size some of you all have. Most of us are like minded with hobbies and stuff.
    Three kids who enjoy the same stuff have me squeezed at the gills
    I have 2 Amish built 12 x 25 "high side" sheds and one 10 x 20 also.
    I had them add metal roofing and one of the "whirly bird" roof vents to each one when I ordered them.
    All 3 are the "barn style" roof so I could do overhead storage more easily.
    Also have a 12W x 14H x 30L Shelter Logic pipe frame "carport" that we put up 2 years ago to put the Shamrock into while we did her winter overhaul.
    If you go with one of them, add the roll up end door kits and go with the heavier (not standard) material thickness...it is guaranteed for something like 15 years.
    1992 211 w/175 OptiMax
    Glen Campbell, Pa.
      How much room do you have and what are your town variances? For example, my town allows up to a 8x10 shed no closer to the property line than 4 feet. Anything bigger and it has to be 16 feet from the property line.
        15' x 36' with 10' x 12' high OH door. Should have built it just a little wider. 18' would have been perfect, about 5' each side.
        It's just a simple pole barn addition to the original barn.
        Ole Joe
        Just floundering around
        1978 Mako 25
          Anything over 100sq ft i need a permit
          Anything over 1000 sq ft needs inspected if stick built
          I have plenty of room. Are set backs are 3
            We originally had a 8'x16' that was good for a number of years ... Could get the rider mower in easy ... More recently got a 10'x16' and the extra 2' makes a difference ... More recently just built a 28' x 30' garage and that beats all. This one I can pull the Mako into ... Which was the original plan!
            72\' Mako 22\'[br]NoNeck, VA
              Thanks. I think that will be my goal for next year. Build a garage with min 1000 sq ft
                6x12 for me and I wish it was double that but I am limited by the city.
                  My barn is 42x 26 with an 11' apron on the front. Experience tells me that no matter how big you go you'll always have enough junk to fill it!!
                  '90 Tuppens 231 Polk City, FL
                    post the IMG code in photobucket
                    David, New Kent, Va[br]
                      [/quote]
                      [/quote]
                      It was there before but now I can't get into photobucket. Their site is down for some reason.
