Power winch setup
  • Power winch setup
    I have a power winch on my trailer and I have never hooked up the power cable permanently. I tow with a F150 and was never crazy about running the wire under the truck and hooking directly to the battery for power and the frame for ground, I never had any great idea of where to run and store the wire. Typically I use a battery pack jump starter to power the winch. Wondering what other guys do for power to a powerwinch? Thanks.
    I ran both the +/- directly to the battery, along the frame, without issue. Got everything on Amazon for roughly $60, lugs, #6 wire, and quick connects
    Runs my 10,000# winch fine, nothing gets hot
      DMack sent a picture of how he set his up recently. he said it worked fine in the driveway but his troubleshooting why it didn't work at the boat ramp.
        Slacker, I would have put at least two more wire ties on there. []
        David, New Kent, Va[br]
          That's why it's called the "hot wire".
          Ole Joe
          Just floundering around
          Shrewsbury, Pennsylvania
          1978 Mako 25, Sold
            Rather than run a #6 cable to the winch, why not add second battery on the trailer with a normal sized, fused charging wire? Thats what
            I did for the winch on my trailer.
              Originally posted by Jeff258
              Rather than run a #6 cable to the winch, why not add second battery on the trailer with a normal sized, fused charging wire? Thats what I did for the winch on my trailer.
              That's what i am leaning towards, what do you do for charging? I only have about 1/2 mile run from the house to the ramp, so vehicle charging is probably not an option. Thanks.
                A 5 watt Solar panel and controller?
                  Hahahahaha
                    That must be one of those new "Slipp-Zipp" ties I've heard so much about on the drive shaft.
                    M20 project-Finally Splashed!
                    Gallery
