I've never had a powder coating pretty much on anything. I'm wondering, if you have a T-Top that was factory powder coated, and you want to weld some additional rod holders to it, is it possible and how does it generally look if you try to re-powder coat it? I'm assuming you'd have to grind off the coating where you want to attach, but then does the heat ruin the coating near where you weld?
Powder Coated T-Tops question
I did my t-top 12 years ago and welded before powercoating. I'm not sure how it would come out welding a top and touching up the powercoating. Never tried re-baking already baked powercoat and do not know how it bonds (melts) with the new material.
D-
