NEW MAKO 23'1 OWNER WITH 250HP MERC AND IN LOVE WITH MY MAKO''''''Has anyone plugged up the scupper holes or has anyine put scupper flaps on the transon scupper holes??
Flappers, ping pong balls and tht thru hulls with replaceable flappers.
Maybe plug up when your on the hook with rubber stoppers when youre on the hook but attach a string so you can pull them to bale water pronto . Whats wrong ? You getting water in when fishing aft at rest?
Welcome to CM! Tell us a little more about your setup. What motor, single or twins, bracket/no bracket, etc. I am assuming you are getting water on the deck? Have you moved your batteries and/or oil tank under the console? Getting as much weight forward, along with good scupper covers and possibly splashboards will help mitigate wet decks.
