new guy
  • new guy
    Hi. I have been lurking for a while, I bought a 98 232 last year and have been slowly going through it and cleaning it up. Ill post pictures later as I go.
    Welcome. If you don't post pictures you don't own a Mako...[] We need boat porn. What motor do you have? Whats projects have you completed
      98 Johnson 250, rebuilt sea star steering, trim and tilt and Im working on stripping the old bottom paint, replacing all switches and gauges and re wiring the console. I need to cut the bracket to remove the foam, found another thread that suggested pulling the anode bolt and sure enough it started dripping.
        I assume factory bracket? Most have moved away from foam filled brackets and built the largest tub possible for flotation. Congrats again on the purchase
