1979 Mako 236 Prop Help
  • 1979 Mako 236 Prop Help
    Hey guys!
    Picked up a 236 with a diesel Volvo Penta 165hp turbo, 1979.
    The boat has a 17 prop with a 19 pitch. When I water tested it it was really struggling to get up on a plane. I had a seized heat exchanger which I have recently replaced. I am waiting on spring to roll around to water test again. I mention this because the engine was getting too hot to really and try to level the boat out.
    I was wondering if anyone knows what size props they sold with these boats or if anyone has current experience.
    Thanks!
    I have a 1976 23' with a 225HP Mercury outboard.
    I went with a Quiksilver Q4, 17P at the suggestion of Ken @ Propgods. It was a spot-on recommendation!
    He suggested stepping down to a 15P if I couldn't get enough RPMs out of the engine (I can run fully loaded WOT at 5,200 RPMs, so that isn't an issue.
    Based on all that, I wonder if that 19P will be too much for your boat? I'd suggest sending Ken an email and getting his recommendation.
    [email protected]
      tough call, since there are not that many diesel 236s...although I would love to increase that number!
      I could state my config, but it would not matter, because I have a 330hp gasser with a 1.5:1 transmission; a diesel is turning slower, and your gear is not stated, so cannot even ballpark...you are in a different stadium altogether!
      You may want to try to call Frank and Jimmys prop shop in Ft. Lauderdale. They have many decades of knowledge. I also heard that Acme props are very helpful.
      The takeaway being, call a professional prop shop for the best answer to your specific configuration.
      Oh...and post the results! this forum is a great repository of knowledge for all things classic mako!!!
      [br]DonK[br]Boca Raton, FL[br]1979 236IB: \'The Fish Tank\'[br]1979 Backcountry 18 \'Boner\'[br]<>< <>< <>< <>< ><> J[br]Redneck Troubleshooting:[br]1) If it moves, but ain\'t supposed to, use Duct Tape[br]2) If it don\'t move, but supposed to, use WD40[br]3) If that don\'t fix it, it\'s electrical![br]
