1987 200 Johnson Ocean Runner
  • 1987 200 Johnson Ocean Runner
    Hello all,
    I am new to boating and purchased my first boat last summer. Its a 1977 21' Mako with a 1987 200 Johnson Ocean Runner.. It ran great all Summer - towards the end of the Summer I noticed it was burning blue smoke a little longer than normal when I started her up... The other issue is that 50% of the time is stall's when I drop it into neutral -- very nerve wracking for a new boat owner when docking (it always fires right back up). Its out of the water now - i am looking for suggestions on how to prepare for the 2017 season and don't want to get totally ripped off by a mechanic...
    Thanks~
    Tom
    I encourage folks to change their spark plugs twice a season, with the proper plug and gap. If your still running the VRO oil injection you may have a problem with the oiler pump. When they fail they tend to over oil. On an engine of that age, I would seriously consider removing the oil injection and running 50:1 premix.
    If you dont know how old the water pump impeller is you may want to consider changing it, along with the lower unit lube. ALWAYS put anti seize on every bolt you remove. You may want to run a compression check also to get a baseline health estimate on your engine. Those were good although thirsty engines. but all 2 strokes are a bit thirsty...
    d
      d
        Thanks Michigan Dave. I will have this conversation with the mechanic in the Spring. Ball park figures, what would all of this work cost if I do it before dropping her back in the water. Its moored, and I don't have a trailer so I would like to address it before its back in the water.
        I really appreciate your insight.
        Tom
          The stalling when coming back to neutral suggests dirty carbs to me. The excess blue smoke could just be regular 2-stroke oil or as Dave suggests tied to the VRO over-oiling, which could also contribute to plug fouling and rough idle / stalling.
