Bow eye bolts
  • Bow eye bolts
    So I'm guessing I have to cut through the anchor compartment on my 74 mako 20 to access the bow eye bolts?
    1990 286 [br]74 mako20
    IT should be visable when you take the anchor hatch cover off. At least it was in my 21. There may be a piece of wood with screws in it covering the threaded rod and eye bolt.
      There is a fiberglass molded piece that fits inside the bow anchor locker. Your bow eye bolts are right behind it. When I replaced mine, I cut a rectangular hole, dug out the foam and was able to remove the bolts and replace the bow eye. I cut a piece of starboard to fit over the hole and attached it with screws so that I could get back in there again.
        Ok thanks, thats what I figured just making sure before I go cutting into stuff!
