Mako 17 (76')__cockpit drains replacement
  • Mako 17 (76')__cockpit drains replacement
    My 17 Mako is 37 years old and the below deck drains are leaking. This makes for a very risky trip when the boat remains in the water for several days.
    I have the angler model.
    There are 2 cockpit drains, and 3 box drains. The 3 box drains are accessible via the large access hatch just in front of the engine.
    The 2 cockpit drains are not accessible through this hatch.
    There appears to be foam and a fiberglass sub-floor blocking access.
    I am really not wanting to separate the inner cockpit liner from the hull.
    Does anyone have any experience on replacing these drains and their hoses.
    Captiva Shack
    Glen Weeks
    If they are leaking your boat more likely has water logged foam causing more weight back there keeping drains submerged and probably your boat may seem slower
      It is a hard reach but you should be able to get to the cockpit drains. Mine had hose that was hose clamped onto the drain and i was able to reach and replace it. Cant say it ws easy but it can be done.
