fuel tank removal and replacement
  • fuel tank removal and replacement
    I have had a 79 17 ft.since 1988. The fuel tank needs to be replaced. Any words of wisdom? Any ideas as to where I can find a diagram of oem tank? Who offers a replacement? Any pros or cons on a plastic over aluminum?
    All kinds of info on here. Try doing a search for what you are after and change to subject only. There are many of tank builders. Some are very good, some are good and some might make you go boom! It's a lot of work and all the odds n ends to do the job right adds up. If you pull the tank out you can get the measurements you need for a new one. I replaced mine this spring and sunshine marine in fl built mine and shipped it for less money than several others. They are great to work with, good valvue
