lifting method on 225hp
  • lifting method on 225hp
    Re:1998 Johnson 225hp (about 450 lbs) - Recently someone told me that I could lift the motor by inserting three bolts in the flywheel (used for flywheel puller) and use a steel gusset plate with a lifting eye. My gut tells me that if this was a convenient means of lifting a motor then everyone would be doing it.
    If not, then what is the best way to attach & lift this size motor?
    Any comments?
    Amendment: I received one suggestion of using a flywheel / crankshaft nut welded to a lifting ring. Is lifting the 450lb motor from the crankshaft an acceptable method?
    Capt Mud Flat[br]\'73 Mako 232[br]Mandeville, LA
    I just lifted a Yami 225 and it had a lifting point on the motor. I did a 225 Evinrude last year and it had 2 lifting points on it. One on the starter bracket and the other on a head bolt.
    '90 Tuppens 231 Polk City, FL
      Any comments?
      The method of using a plate with a loop mentioned above, is one of the primary methods you will find stated in a number of repair manuals, and will work fine.
      If you have acess to such a lifting plate, or build your own, just make sure your plate has holes properly spaced to match the flywheel's threaded holes, and that you engage the threads to a depth of approximately the diameter of the bolts (IE: you do NOT want to be lifting using only one or two threads, which may pull out of the flywheel, causing the motor to drop to the ground suddenly...[V])
      So... You can either locate & borrow/rent such a lifting plate, fabricate your own lifting plate (I've made many such plates for a variety of engines in my lifetime), or in a pinch for a one-time use, use a short section of chain, into which all three of the bolts can be inserted making two loops of equual length that can be used on your lifting hook to lift and support an equal portion of the load.
      FINALLY... IF you have an extra flywheel nut and want to weld a loop onto it, that too could be a way to skin this cat, but you will want to replace it with a new one aAND properly re-torque this new nut upon re-installing the motor into the boat. IMHO, this is just extra work... [:I]
      HTH... []
        Any comments?
        HTH... []
          Thanks Wpeavy and ov1jeeper.
          I received a few emails all stating mostly the same thing. One guy has such a rig that he will loan me and hes only a 20 minute ride away.
          FYI, after I posted this I googled it and there are several for sale on eBay in the $40 - $90 range. Also, there are a few YouTube videos on the subject.
          This will be much easier than attaching chains to power head bolts.
              Advance auto or Auto zone has a tool loaner program. The harmonic balancer tool is what you want. The hardware store will have the large eye you need for the balancer and the fine thread 5/16 by 3 inch bolts you need to screw into your flywheel. Be cautious that you dont run the screws more than a inch down into the flywheel. The stator lives on the underside and the bolts can go down into it and damage the stator if you run them way deep/ This is the same tool you will need someday to pull your flywheel and service your stator or voltage regulator, or flywheel magnets.
                  X2
                  The Loaner tool kit will even come with the various bolts. The only out of pocket is buying an eye bolt, nut and a washer
                    X2
                      Harmonic balancer puller, I had one its what I pulled my Merc 3.0L (225) with to replace the tiller arm.
                      Worked well, and was free as I had it handy.Otherwise most autopart chains have the free tool loaner deal.
