Yamaha OX66 Piston
  • Yamaha OX66 Piston
    So, I think I pretty much know this motor is shot after just 800 hours but I'm not sure what would cause this piston to project so far out of the block. Seems like it was getting plenty of lubrication and it doesn't look overheated. It was definitely hitting the head. Shame because the rest of the cylinders are fine. Bad crankshaft bearing?
    crankshaft bearing sounds like a real good guess. Report back when you get deeper into it.
    Rick Loszewski[br]Derry, NH
      rod bearing or wrist pin bearing
        The piston was not directly hitting the head, but did ingest and hit some foreign object which moved around a bit before finally getting spit out the exhaust port. Likely the rod bearing or a piece of a broken ring. You can tell by rolling the motor over slowly until the piston starts to travel back down, stop and try pushing the piston a little with your thumb. If there is rod clearance you will discover it then, as it will move in easy until the clearance is taken up. When a rod bearing fails on a two stroke it gets moved around and up through the intake ports and finds its home at the top of the piston. two stroke rod bearings are needle bearings contained in a shell. Dont rebuild the engine unless you have your injectors all checked, to find the source of the problem.
