Blew my rectifier should I also replace stator?
  • Blew my rectifier should I also replace stator?
    Engine is a carbed 2002 Evinrude 175 hp looper.
    Boat was running awesome as they always do before they break.
    All electronics optical sensor, powerpack, stator and rectifier are less than 2 years old.
    On the way out I noticed the tach stopped working and my volts dropped to 12ish but still had to run 15 miles to get back to the dock. The engine ran fine on the way back even at WOT so I think the powerpack survived.
    The wires on my 2 year old CDI rectifier are burnt where the wires enter the pack. You can see where the plastic melted.
    I took out the stator and watched a few Youtube videos on how to test them but I need to visit the CDI site. The stator looks OK. Epoxy is not oozing out or anything. One of the magnets (the one by itself opposite the other two) seems a little loose. Magents on flywheel are good.
    From the testing I have done the battery is not charging (steady 12.3 volts at any rpm), There is no voltage coming out of the purple wire (0 volts) to the tach.
    The DVA volts on the two fat yellow wires between stator and rectifier are 81 and 50 volts. Seems high as CDI mentions 18 to 20 with a 2 volt variance.
    I definitely need a rectifier but I'm not sure about the stator????
    So do I buy both or just one??? Labor day is right around the corner.
    If you have a DVA and can test the stator and see it's failing, replace it.
    If you're unsure...if you already have the flywheel off, I'd probably just replace the stator anyway given you're in there.
      I have a DVA but already took the stator off the engine.
      I'm going to test the ohms now that I printed CDIs specs.
        The stators ohms are all within specs.
        I would have to install it again and run the motor to get DVA numbers.
        If the ohms are within specs does it mean it is good?
          Not necessarily, no. That said, a bad stator will typically kill spark to a bank. Your description of the tach, plus the fried regulator wires, does point to the regulator not the stator.
            The regulator gets here tomorrow.
            Is there any harm on just installing it and starting her up on the muffs after checking wires and charging batteries???
              Yes, you can reinstall the regulator and current stator, and flywheel, start her on muffs and confirm spark on all cylinders and check charging volts at battery.
                Thanks. I never lost spark at all even at WOT.
                The boat ran well even when the Rec took a dump.
                  Replaced the rectifier got my tach working and batt cahrging.
                  Found some rust on the cables so I am buying tinned cables with tinned ends.
                    It motor running fine again?
                    congrats on getting it fixed always a good feeling
                      The motor ran fine for 15 to 20 miles right after I noticed no tach and no charge.
                      Even after that my batts were still at 12.3 and 12.4 volts.
                      I just ran it on the muffs till I charge the batts, replace cables and look for the cause.
                      I'm happy it was just the Rec.
                      Last time it was the stator, rec, power pack and optical sensor. $800 in parts.
                        Look for some loose battery cables, especially on the battery selector switch. Usually the rec/reg will blow if it has no where to deliver the current. All the bouncing around loosens things up. At this point I have stainless Nylocs on almost everything. A bad cell in a battery will also do this. But you say you have 12.4 with engine off, so not the case
                          Everything was tight but I did find some rust on the common ground cables.
                          I'm waiting on new tinned cables
                          Batts are at 12.9 two days after charging.
                            I replaced my old battery cables with some hd tinned cables from Genuinedealz.
                            It was a very big improvement when starting the engine on just one battery.
                            Before I had to start the engine on both batteries whereas now it starts right up on just one.
                              Well done....Green connectors are not good...LOL....now get some fish....
