Suzuki Outboards
  • Suzuki Outboards
    I am repowering my 1988 231 CC. I am deciding between a Suzuki 200A & a 225. I live in Annapolis & will be running her in the Chesapeake. The outboard will be attached to the transom. She had a 1998 225 Johnson Ocean Runner on her before. The owners manual states max power is 250. The dealership is trying to push the 200A for its features & great reputation. Im leaning towards the 225 to have the extra power since I have drag from my t-top. The price is not a huge difference between the two. I would appreciate it if anyone would chime in. Thanks.
    Our hulls are similar, the 231 is a little bigger, and while I do run a 200 it is a 2-stroke and got because timing was right. If buying new and not constrained by budget I personally would not consider 200 4-stroke.
    I understand the reputation, but what features does the 200 have that arne't available on the 225? Is it possible they have a 200 in stock?
      buddy has a 231 with a 225 and runs fantastic. I would think a 250 would be an even better bet as the larger engine could run the same speed at a slower rpm. Plus if you ever decided to sell, your boat would sell much faster with a 250 or 225 then a 200 just due to perception.
        I opted for the 250. The 200 and 225 will only net you about 1 or 2 mph different. The 250 jumps up in another class and is closer to the 300 in turns of HP and MPG. Hit up Brando as he as a 250 on his 23 WA. He loves to show it off.
          ChuckB, the 200A is a 4 cylinder while the 225 is a 6 cylinder.
          The 200A offers variable valve timing system, lean burn control system, O2 sensor feedback control system, easy start system & troll mode system whereas the 225 does not have any of those options.
          Th 200 weighs 529 lbs while the 225 weighs 606.
              Snappergapper, are you saying there will only be a couple of mph different between the 200 & the 225? If so, how did you come up w/ that? I would go w/ the 200 if what you are saying is true. Thanks.
                and from what I was told by Danny's Marine when I was price shopping was the 200 is available with Fly-By-Wire and the 225 only has mechanical controls
