Help!__Evinrude 200 Looper won't go above3000 rpms
  • Help!__Evinrude 200 Looper won't go above3000 rpms
    I finally got around to taking the boat out for the first time since last summer and the outboard is having an issue, it won't climb above 3000 RPM. Its a 1992 200 hp Evinrude. Its almost like it stutters, but it just will not climb above 3000 RPM. I cleaned the carbs and replaced the racor filter and took it out again and no difference. The fuel is fresh and it has even compression across all cylinders. The outboard has the VRO pump disconnected and has an electric fuel pump. It starts and idles fantastic.
    I'm at a loss to what to go after next. I feel like its got to be a fuel issue, but I don't want to just throw parts at it.
    Thanks in advance!
    https://youtu.be/tsORL3eaunA
    1982 Mako 21
    Sounds electrical? Is the throttle linkage opening up the carbs all the way? Plugged filter?[?]
      Carbs are definitely opened up all the way.
      Changed the fuel filter prior to the last test.
      I just got a spark tester today, so I was going to verify I have good spark on all cylinders.
      1982 Mako 21
        Had the same issue on a friends motor. First check that your shift interrupt switch on the motor is working correctly. It's a switch right but the shift lever in the motor, it cuts 3 cylinders out for a split second to ease the load on the motor when shifting, if that is good, then you have a bad voltage regulator. My buddy had twins and the first time it port motor and had a bad shift switch, the second time it was starboard motor and after checking switch it turned out to be voltage regulator.
        Gabe
        Savannah, Georgia
          Oh and you can check the shift switch by simply disconnecting it.
          Savannah, Georgia
            I've never used a spark yesterday before , but it does light up on each cylinder, not very brightly but it does light.
            Also, as I was messing with that I pulled all the plugs and the one in the port side bottom (or maybe middle I'm not 100% sure which it came out of) was significantly better than all the other plugs. Any thoughts on what that may indicate?
            1982 Mako 21
              Oh also, I don't have the shift switch on my motor nor can I find the black and yellow wires that are supposed to be on that circuit anywhere. I see the spot on the shift bracket where it should be but it's not there. I think I've ruled that out anyways since I do have spark on all cylinders.
              1982 Mako 21
                you are sure it's 3000 rpm?
                might be in s.l.o.w check and see if the temp sensors are shorted by unplugging them and trying to run the motor
                  Check your ignition system. Failing stator can kill a bank, failing timer base can cause weak/erratic spark. Could also be powerpack...
                    Isn't 3000 the magic number for safe mode? So low oil or overheating condition.
                    Was the VRO disconnected properly and the oil sensor unplugged?
                    If you're premixing and not truly overheating, i would unplug the sensors and see if you can go above 3k
                      It is definitely 3000 rpm. The vro was disconnected before I got the boat 7 years ago and it's run great up until this.
                      I will unplug the sensors and give it another go.
                      How do I test the timer base? I've got a shop manual but don't recall seeing anything about the timer base.
                      Thanks again.
                      1982 Mako 21
                        I believe safe mode is 2500...it is on the 90s loopers.
                        To test the timer base, you'll need a DVA meter.
                        When you say you cleaned the carbs, did you take them apart and go through them with new gasket kits? When at 3000, have you tried choking/priming the engine and seeing what it does?
                        If you are 100% sure it's not fuel-related, it's ignition. Your report that 1 cylinder seems to fire stronger than the others would suggest ignition.
                        Start reading on page 53
                        http://www.cdielectronics.com/wp-con...20-%202012.pdf
                          Get a dva adapter that will plug into your digital electric
                          multi-meter. I use fluke meters and love them. You also need a factory service manual. Look on EBay for a dva adapter and factory service manual. Don't get a clymer manual.
                            A lot of times when you have 1 plug that looks so much better than all the rest its because its not firing well and the fuel is washing it clean...
