I have a 1986 20c Mako boat with a 200 HP 2000 Yamaha Saltwater series OX66. When I bought it, it had a Seastar hydraulic steering.
Fast forward some years of use and now it's leaking oil through the seals in the piston. I don't know the model because the stickers have faded. I got the somewhat expensive tool from Marinetech to extract the support brackets. I also ask around between vendors, and they recommended buying the seal kit HS5157. That one comes with a wrench for the pins in the piston caps.
The issue that I am having is that my hydraulic piston caps have no pin holes, or for that effect, no markings whatsoever. All they had was a circlip inside the edge of the piston, which I already took out. But I have no idea whatsoever how to take out the old caps. I noticed that at the end of the main rod, there are two (maybe threaded inside?) holes. I have already sunk a lot of money on other repairs, hence I am avoiding buying a new steering unit.
Attaching some pics, any suggestion would be greatly appreciated!
