Yamaha Lf300xca, 300 Hp, 25' Shaft, Digital, Electric, Pt&t, Offshore 4.2l
  • Yamaha Lf300xca, 300 Hp, 25' Shaft, Digital, Electric, Pt&t, Offshore 4.2l
    All our outboard Engines are brand new original, working perfect in good conditions. we carry 4 strokes outboard engines from 20hp to 350hp of different brands such as Johnson, Evinrude, Yamaha, Honda, Suzuki, Tohatsu, Mercury outboards
    Purchase your choice of quality outboard engines at cheap and affordable price.
    Contact for Purchase.
    Sales Manager: Rayhan Jafar Mikhail (moto Centro Limited)
    Mail: sales. motocentroltd. com
    website: www. motocentroltd. com
    Whatsapp Chat Number: +14848419285
    Price: $8500usd
    Brand: Yamaha Motor, Yamaha Motor
    Weight: 229 kg (505 lbs)
    Manufacturer Item Number: Lf300xca
    Warranty: 3 Year Limited Pleasure Boat - 1 Year Limited Commercial
    Degree Of Tilt: 67°
    Thermostat Controlled Cooling System: Standard Feature
    Alternator Output: 50 Amp, 70 Amp
    Bore And Stroke: 96 x 96mm (3.78 x 3.78 in)
    Carb Rating: 3-star
    Compression Ratio: 10.3:1
    Cooling System: Thermostatic Control
    Degree Of Trim: -3° through +16°
    Displacement: 4.2l (254 ci)
    Engine Oil Capacity: 6.3l/6.0l w/with filter
    Engine Type: V6 Four Stroke
    Exhaust System: Through Propeller
    Fuel Induction System: Electronic Fuel Injection
    Gear Case Rotation: Standard (rh)
    Gear Shift: Forward, Neutral, Reverse
    Gearcase Ratio: 1.75:1
    Gearcase Rotation: (lh) Counter
    Horsepower: 300
    Ignition: Tci Microcomputer
    Intake: Single Throttle Valve
    Model Number: Lf300xca
    Mounting Centers: 28.6'
    Multi Function Gauges: Optional Equipment
    Oil Capacity: 6.7l/6.4l
    Power Trim & Tilt: Yes
    Recommended Fuel: Octane 87, 10% Maximum
    Recommended Fuel Filtration: Yamaha 10-micron Fuel/water Separating Filter (external) Standard Feature
    Recommended Oil: Yamalube 4m (see owner's manual)
    Shaft Length: 25'
    Spark Plug: Lfr6a-11-00-000
    Starting System: Electric
    Steering Angle Maximum: 32° from center, either direction
    Yamaha Propellers: Optional Equipment
    Year: Current
    Command Link System: Compatible
    Full Throttle Rpm Range: 5000-6000
    Lubrication System: Wet sump
    Mail: [email protected] com
