1993 221B,,,,,,,,,,,is a 150hp Ocean Pro enough???
  • 1993 221B,,,,,,,,,,,is a 150hp Ocean Pro enough???
    Has a 225 EFI Mercury on it . OIl pump gave out, engine seized,not worth rebuilding.....Sooooooo found a strong clean evinrude OPro 150....100lbs lighter than the efi,,,,I am not top end speed freak, just fishin,scalloping and cruising....150hpOpti I think was stock on these original
    You can never have too much power. Seriously.
    I suspect you'll never be happy with a 30% reduction in power. Will it work? Probably. But that's a lot of work to swap over engines. I'd think long and hard before pulling the trigger on that one.
      I think the 150 will move the boat around but you would be disappointed with the performance. 200hp would be ok, 225hp would be pretty good, 250hp would be great.
      Current
      Previous
      Brick, NJ
        I found a 225hp ocean pro......perfect fit/////150hp would of sucked
