Rigging Tubes
  • Rigging Tubes
    I am wondering what people are using for rigging tubes, material and size?
    Do you run a single tube from console to transom?
    Does it have drain holes in it?
    jamie
    Toronto, Canada
    76 Mako 23
    four inch PVC you have room, if not then a 3" pvc and best to run one on each side. You will run out of room quick with one rigging tube.
      Is there a reason why PVC is used and not ABS?
      Toronto, Canada
      76 Mako 23
        Suggest using sweeping elbows rather than 90deg elbows because of bend radius of some control cables.
        Keyman[br]Paoli, PA
          I used 3" schedule 40 ABS and used a 45 and street 45 for coming up through the floor. I also ran one on each side, lots of room for my setup inside the 3". No drain hole, just slope it down towards the bilge.
