Whats up guys just wondering what size tank everyones replaced theirs with. Ive been searching with mixed results. Found either a 30 gallon Moeller or get one custom built. If so what are the dimensions??
1973 mako 19 fuel tank dimensions
Below is a drawing of the OEM fuel tank dimensions from my 1972 Mako 19. I had a new aluminum tank fabricated to these specifications.
If you are replacing the fuel tank I would also replace the fuel tank fill pipe that runs down the portside gunwale turning under the deck toward the fuel tank coffin.
I used Atlantic Coast Welding http://www.speedytanks.com/
Also many here have used Sunshine Marine Tanks http://sunshinemarinetanks.com/
Hope this information is helpful!
Eric
1972 Classic Mako 19
Eric
