25 forward bilge question
  • 25 forward bilge question
    My 25 had a thru hull transducer and bonding bar(thru the hull) in the forward bilge.
    I want to put a 3/4 thru hull and seacock in
    for a saltwater wash down. Do these boats need a bonding bar and can you put a transducer in the forward bilge? .
    Some components used the grounding bar back in the day. You can get rid of it. Side note, it's a good idea to bond all your thru hull fittings to your negative side of your battery. I would use the rear bilge for transducers
      You can put a transducer up there but it won't read very well above five knots, just too much turbulence. Much better in the keel near the stern.
