Coffin lid
  • Coffin lid
    Getting ready to recore the coffin lid on a mid 90's Grady White. Sorry it's not a Mako, but my Mako lid might be next. Haha.[]
    The lid is 25" x 64" I was going to use US Composites 3:1 ratio medium hardener epoxy with 1708. Plan was 1 layer of 1708, 1/2" plywood pieces, then 2 layers of 1708. The 1708 is 50 inches wide, so I was thinking 5 yards would be more than enough. Will 1 gallon of epoxy do it? Anything else?
    Rick Loszewski[br]Derry, NH
    1708 is designed to be used with poly resin -- epoxy wont dissolve the binders in the CSM backing.
    You could use poly resin (many do), and I'm going to guess you'll need more than 1 gallon. I think I used over 2 gallons on my coffin lid.
    If you really want to use epoxy, switch to 1700 fabric. 1700 will require less resin than 1708, but I still think you're cutting it close with 1 gallon.
      I could use polyester resin. If I do, what is the recommended layup schedule? Some searches look like this:
      1.5 oz CMS
      1708
      core material
      2 more layers of 1708 or 1808
        1.5 oz CMS
        1708
        core material
        Yes, that's a good layup. Depending on how thick it is when you get all the old core out, you may be able to skip a layer on the bottom (really the top)...but what you have there should work well.
          I would use epoxy if using a wood core and coat it first. The problem with binders and epoxy is when using straight matt. You can use 1708. Itll take more resin to wet out and is unnecessary for strength than using 17 oz. biaxial but it builds thickness quicker. One layer on either side would be plenty. Vinylester would be my second resin choice but again coat the wood first. You dont want the wood sucking up your resin leaving you with dry glass.
