Transom rebuild from the inside
  • Transom rebuild from the inside
    I have searched but cannot find any threads showing how to rebuild a transom from the inside. Anyone know of any?
    1973 Mako 22, 1982 200 HP Johnson[br]1986 Bayliner 3270 Motoryacht, Twin Hino Diesels
    Many have been documented here.... grab a coffee, settle into a comfortable seat and enjoy the reading.
    http://www.classicmako.com/projects/...m_rebuild1.htm
    http://www.classicmako.com/forum/top...TOPIC_ID=44076
    http://www.classicmako.com/forum/top...TOPIC_ID=57188
    http://www.classicmako.com/forum/top...48&whichpage=1
    http://www.classicmako.com/forum/top...Topic_ID=37475
    Eric
    1972 Classic Mako 19
      Thanks Pole Lock for the links.
      Looking at my 1973 22, it appears the deck of the boat becomes one piece with the transom/hull. Is this factory or has my transom been rebuilt in the past? I see signs of brownish red fairing compound in a few areas. I noticed this when trying to figure out where to cut the deck and splash well area to obtain access to the inside of the transom. Does anyone have pictures or a sketch showing where to cut for this year/size of Mako?
        Check out this thread...I think you will find it very helpful []
        http://www.classicmako.com/projects/...i/havanki1.htm
        Eric
          PoleLock, thanks for the link, that is just what I've been looking for.
            Welcome to CM! Are you using Google to search?
            http://www.classicmako.com/forum/top...TOPIC_ID=52507
            What core are you going to put back in?
              I would never re-do a transom from outside. From the inside allows you to keep that outer skin to hull there and allows tying into interior floor sides and stringer. Cut back stringers cut out inner skin grind out wood. Template a new core.
              I learned from the project threads on here. Great source for all things boat projects.
                Each has it's own merits and places and nothing wrong with either.
                1978 Mako 25[br]
