TROLLING MOTOR ON MAKO 224 -1
  • TROLLING MOTOR ON MAKO 224 -1
    Forward of console. Two to left are Boat; three to right dedicated to Trolling Motor (TM).
    Breaker and charger (3 bank Powermania) for TM
    Another view of Breaker and Charger
      Thru-console view
        TM Power out to starboard gunnel
          Power run starboard gunnel plate.
            Power terminates at plug.
              They (Mike and Scott) mounted this 60" TM just for demo... mine will be 72"
                Running lights removed; TM mount installed
                  1/2" Starboard on bottom; 1/2" powder-coated aluminum; Minn Kota mount on top.
                    Boat should be complete next week. Also installing Thru-hull transducer B175M, and Groco thru hull for live well and raw water wash-down. More to follow
                      What size motor do you have on the back
                      seaford ny. 1973 17 mako. 1983 21 mako
                        200 HO
                          looks great! I'll admit, wasn't a fan of the looks of the new 'rudes but they are growing on me...
                          any change in the ride with all that battery weight under the console?
                            Boat is still in shop. Trolling motor install is almost complete. Left to do are: Install shark eye running lights into cap; install Airmar B175M thru-hull transducer to Garmin 741xs; install Groco hi-speed pickup, sea cock, pump to livewell and raw water wash-down. Second sea cock installed in starboard splash-well for ease of operation as pictured. Boat should ride very solid. Expect completion this week if all goes well.
                              Any update on how this worked? I have thought about doing this to my 221 as well. Was the 72in shaft long enough? I'm sure the 36v has enough power.
                              Boat by HUNTER BEALL, on Flickr[br]1992 Mako 221[br]Pascagoula, Ms
