Mako 231 Drain Tubes
  • Mako 231 Drain Tubes
    Has anyone replaced drain tubes on a 231? 1 1/4 are too small and I cant find 1 1/2 anywhere. Boat is a 1989
    1989 Mako 231
    Check out Moeller Drain Tubes from Jamestown
    https://www.jamestowndistributors.co...er+Drain+Tubes
    id="Times New Roman">id="size4">
    Charles-Pearland,TX
    Sea Reel- 1977 Mako 25 SOLD
      Are you looking for the main bilge drain or livewell drain?
      If the main bilge drain, I'd drill out your existing hole just a bit to get fresh material, epoxy the hole entirely closed.
      Then used a 1 1/4 hole saw to refresh the hole. And just use a garbord drain on the hulls exterior.
      If for the live well I'd do the same thing but install a new thru hull instead of the garbord drain..
      Hope this helps.
        There are 4 drain tubes (2 on each side) underneath metal scupper. Water drains out of the splashwell through them. I am also replacing the others but they appear to be 1 1/4 so shouldnt be a problem. The 4 above the splash well are larger than 1 1/4 so Im thibking they must be 1 1/2. I cant find brass ones anywhere but found some plastic threaded tubes that I am going to try
        1989 Mako 231
          Here is a link to some work I did on my 25 at the time:http://classicmako.com/forum/topic.a...rms=drain,tubeid="Times New Roman">id="size4">
          Charles-Pearland,TX
            Check out letsfish231 post he re did all of his drains and transom holes woth thruhull recently.
              Thanks for the replies. I am thinking I may just fill the old holes, redrill and install 1 1/4 tubes like CReel. Thanks!
              1989 Mako 231
