Foam and gas tank?
  • Foam and gas tank?
    I have a 23 project Im working on and was wondering if anyone has used the moeller plastic tanks instead of an aluminum....I see they offer a 70+ gallon tank and was wondering if this is a better way to go with the ethanol in gas these days?
    My foam question was for foam under the deck instead of using the typical foam for floatation would closed cell spray foam (house insulation) be a good alternative?
    73 mako 20[br]73 mako 23 project
    I just went through this decision for a tank. I installed a new aluminum tank Instead of aluminum. I did not like how with the Moeller tank you need to have space all the way around it and need to figure out how to deal with gas fumes, since the tank is permeable. Not sure about house foam, but I've used house foam for filling holes but mostly use pour foam if possible.
      Q1, no. ethanol and aluminum tanks are not an issue, older fuel lines were not stable with ethanol. Plastic tanks are ok for small applications but I would not use one for a 70 gal application.
      Q2. Do not use spray foam. I used 4# foam from US Composites.
      David, New Kent, Va[br]
