how to solar charge batteries?
  • how to solar charge batteries?
    i keep my boat stored in a lot with no electrical. my 17 has a 24 volt minn kota up front which is depleted after each use. i have no way of charging them except by bringing boat to the house and plugging up over night, which HOA doesnt like. all solar i have looked at simply keeps a battery charged. it doesnt actually charge a depleted battery. any way to do this within reason? only other way i can think of is to chain a generator to the fence and let it work... Thanks for all input!
    A buddy of mine with a sailboat uses a large solar panel that can be in the weather. You could lay it flat on the deck. He uses a voltage regulator and can keep his refrigerator running on the power that it puts out and charge his batteries.
    He bought it all on Amazon for less than $200.
      How quickly do you need them charged? Overnight or for the following weekend?
        just following weekend would be nice
          I've been using a 5 watt panel on my starting batt (1000 CCA) and another 5 watt panel on my House batts (two group 31 deep cycles). I'm on a mooring most of time. I've had this setup for 14 years now and always came to the boat with batts topped off.
          For you I would say a 5 watt for starting and 10watt for trolling batts. And get a good Controller. I've been running these Battery Minder controllers for the past 5 years now. I need to replace them this year since the screws are rusting out.
          https://www.batterymart.com/p-021-11...iABEgIuYvD_BwE
          And get a panel that can stow easily in the boat, unless you plan on leaving them in the car.
          Just to back up a bit. I started off with the Battery minder kit. the panels outlast the controllers. that's why i'm running the battery tender controllers. they handle 5-45 watts. once battery is fully charged, they shut off. they don't trickle charge like most and overcharge.
          https://www.rvupgradestore.com/Batte...1CDE3C8661CA13
          that's my .02 watts.....i mean cents []
            You're certainly not the first to require a large amount of power and then worry about a source of energy.
            Here's a little vid of a similar issue and how they worked through the issue.
            https://youtu.be/f-77xulkB_U
            D-
              D-
              HA! classic!!
              Thanks for the info Delgado.[)][)] that puts me on the right track
