AN ITALIAN MAKO 285 DC
  • nevets
    Hi Bat, Welcome! please post photos so we can follow along with your progress.
  • BAT-MAKO
    Oh What a bad story! I think u've been here during a real political tragedy that involved
    The city in a really bad time.
    That problem was magically solved in the tipically Italian way with the change of the government.
    Thnx a lot for the link
    Originally posted by Shakes_26
    Thats a beautiful area, we love Capri, Sorrento, sorry Naples had a garbage strike when we were there so...stinky.
    Try this for some ideas, I think even sections
    http://www.tek-tanks.com/website/wp-...sign-Guide.pdf
  • Shakes_26
  • BAT-MAKO
    First off, where in Italy are you?
    The baffles I think are simply spaced to reduce the fuel movement in a sea, so even spacing would be more important than any particular placement.
    Just need to make sure they allow for the pickup tube to scavange the maximum amount of fuel with either a bow up or planing attitude of the boat.
    this is a nice one, of course need passages at the very bottom
    Hi Shakes, i write from the Gulf of Naples.
    So u think it's good enough to divide the place. And there is not a rule about the minimum or maximum dimension of the new spaces? I know that i need to permit to the fuel to go into the boxes...
    a google search for baffled marine fuel tank has many results.
  • Shakes_26
  • BAT-MAKO
    Thnx a lot.
    I'm trying to give him every information able to help him in this work.
    So i was searching for rules and projects to follow
  • Sailor
    Welcome to CM and congrats on the 285. I've always wanted one. Any good person who is knowledgeable in aluminum marine tanks should be able to re-create the tank without any issues. Do NOT put a tank in without baffles. The fuel will shift from side to side causing the boat to fall off the keel onto the chine and go from side to side, which is VERY annoying.
  • BAT-MAKO
    So u think i have to try to put baffles inside my tank do empirical evidences (how???) by myself (???) and then give the project to who will do the work or is a simple division of the spaces ?
  • Dogman18
    I'd use the old tank as a model to construct the new one. Outside dimensions and cut it open to see how the baffles were put in location wise.
  • BAT-MAKO
    started a topic AN ITALIAN MAKO 285 DC
    Hi, everybody, i've started reading you 1 year ago when i was searching for my mako.
    Now i-ve got it. I write from italy and now i'm a prudo owner of a 285 DC.
    I've readed everything about it here.
    That was the boat i wanted.
    Now i'm starting to refit it and first of all i need to change the damned fuel tank.
    Can someone help me to find the restore projects about it or tell me where i can find the baffled tank design?
    I think that is more simple and cheaper to find someone here that can do it with aluminum than to buy a new tank in America
    If you want i will do some photos during the refitting of my boat. I hope it will be in sea in june or july 2018...
