86’ 20c Project - Deck / Hull Photos
  • 86’ 20c Project - Deck / Hull Photos
    Hi all,
    I’m working on an 86’ 20c project and hoping someone can help.
    Does anyone have pictures with the floor removed at the bow platform for the 20c? Is there any structure supporting that step up or is it all bearing on foam?
    1. I want to run an 1 1/2” hose from the front storage compartment below the floor and up to a Waste pump out deck plate.
    2. Also thinking of cutting 3 stainless cup holders into the deck, right in front of the storage compartment hatch. Don’t want to create a weak point in the deck though.
    Will post a build thread of this project as soon as I get some time.
    Thanks!
ID:	552866 Click image for larger version
    1986 Mako 20[br]175 Evinrude E-tec
    There were some photos posted a few weeks ago (7/29/21) by Gabriel Damian on the facebook Mako Owners Club. He has modificationed a 1978 model 25. His photos will show you exactly what you can expect.
    Ole Joe
    Just floundering around
    White Hall, Maryland
    1978 Mako 25
      Great, thanks.
      Found the pictures. Looks like it’s all bearing on foam, so it should be ok drilling through the side of that front compartment.
      Any thoughts on cutting in a few cup holders in the deck? Drainage and creating a weak spot across the floor would be my concern.
      A couple pictures from the beginning of this project below.
