1969 MAKO 19 REBUILD
  • #16
    Cleared the rest of the transom foam, need to clear the old wood next and prep it for the new wood.
ID:	553578 Click image for larger version
    • #17
      Dumpster Money, did the 1969's not have an in hull fuel tank? I find this interesting if not.
      • #18
        they do not, external tank. Going to make a custom console and fuel housing.
        • Lews76Mako
          Lews76Mako commented
          Editing a comment
          That is interesting how things changed over the years. Keep up then hard work. Can't wait to see what you make of her.
      • #19
        Originally posted by dumpster money View Post
        You have a build thread?
        My only fear is the floor. Ideally, id raise the floor an inch or two to get better self-bailing. This has worked for a lot of people. But I need to be realistic with my budget and time frame. I think doing the transom, rear stringers, and rear floor should be plenty to make this strong and seaworty. Then I need to do fuel system, console, wiring, paint, and repower. Got plenty of expenses ahead.
        My plan was 2"-6" floor raise. depending on float test. The downfall is how low the sides will be or floor dead-rise.
        My take on time and money is you are there and already and spending a "dumpster load of money"..
        It wound be a shame to do paint and all and need to do something 2-5 years down the road and have to tear into what you already halfway re-did.
        So I am allowing 3-5 years on my total build.
        When I'm done with this build it should be DONE... unless I need to change something around. Tweak Design...
        • #20
          My 69 had a steel 25-28 gallon tank under center console.
          I plan to keep it for Aux. and adding twin 25's under floor,. Had planned twin 60's but they got away/sold before I could go pick up.
          So, using what I have in hand right now. unless something else turns up.
          No highjack intended. Just confirming my 69 as well.
          Remember,. 69 was "some" of the first early Dino's Saurs.
          • #21
            why i need to save this gem, i can only imagine how many 1969 hulls are left... a true piece of mako history.
            • #22
Name:	Screen Shot 2021-10-30 at 10.26.08 PM.png
              I document videos etc here (https://www.tiktok.com/@ruckusreef/v...from_webapp=v1)
              Im getting the rest of the floor off tomorrow.
              • #23
                and if anyone is interested... here is our first mako project. (https://forum.classicmako.com/forum/...g-updated-pics)
Name:	Screen Shot 2021-10-30 at 10.32.54 PM.png
                See it in action here.... (https://www.tiktok.com/@ruckusreef/v...from_webapp=v1)
                • #24
                  More deck removal, here is an original deck cross-section.
Name:	Screen Shot 2021-10-31 at 8.44.00 PM.png
Name:	Screen Shot 2021-10-31 at 8.44.10 PM.png
                  • #25
ID:	554547 Click image for larger version
ID:	554545 Click image for larger version
                    still gutting the hull.
                    • #26
ID:	554561 Click image for larger version
ID:	554562 Click image for larger version
                      Got the front deck open and the foam cleared.
