Hi guys just joined the forum trying to figure out how everything works, scored a 70 19ft for free off a buddy of mine def rough but nothing time and money can't fix
so far just removed motor seats and top sold them for a few dollars towards the fund, hopefully this weekend I'll be putting it on blocks and removing console
Floor and transom both need to be replaced my plan was start with floor and then do transom after wards I've done. One floor in the past with a buddy of mine and as far as fiberglass work goes I'm ok (just takes a little more sanding) will be open to any guidance through out this process
first question, I've seen a few people say it's not a good idea to cut floor and transom out at same time because the boat can rack? My plan with transom was do it from the back and leave the inner skin and also raise the transom in the process, so that being said is cutting both out ok or should I just stick to my original plan as start with floor then do transom afterwards? Thanks in advance
gonna try to post some pictures if I can figure it out
