1988 Mako 17 angler rebuild
  • 1988 Mako 17 angler rebuild
    Here we go. 1988 Mako 17 Angler with a frozen up POS Mercury 115 on the back. This is how she looks when I brought her home.
    First the bow rail, console, tank cover and thirty years of wiring get removed.
    Then the tank, it had several dime size holes rusted through, mostly full of water and sludge.
    Clearwater, FL
    Ironically, I have just started rebuilding the same exact hull and year and have been debating starting a build thread. I have got as far as removing the old deck, rear boxes, stringers and transom. Still going through what seems like endless grinding to get past all the roven woving to a decently consistent inner hull for glass lay up. I also built a cradle for the boat in order to keep some integrity while I remove basically everything.
    I'm thinking of slowing down my process and watching your thread.
      MakoDave.....I am not tearing mine up to that degree. . The transom and deck seem fine. I am replacing the tank, sanding and repainting the hull, patching up the stock console and putting it back together. .
      Clearwater, FL
        Ordered my tank today from Sunshine. They had a drawing that matched my tank exactly. I will pick it on my way to the Keys in a few weeks. Cleaned out the coffin and glassed over the holes. It continues......
        Clearwater, FL
          Suggestion. Do yourself a favor and paint the coffin locker while it’s open.
          —PJ— Navy Vet, electronics nerd, Marine Technician
          1972 Mako 17 Angler with 99 Evinrude Ficht 90hp -> 4 Sale
          1980 Mako 238 with 90 Johnson 225 aka “The Sea Otter II”
            Thanks, but why?, fiberglass doesn't rust, and I don't plan on ever seeing it again once I close it up.
            Clearwater, FL
              No. It doesn’t. But a good coat of bilge paint will protect the fiberglass. Make it last longer. Not necessary, but recommended.
                Might throw some paint on it, with about four weeks until I get the tank, I turned to the console. I took out my cordless drill and removed every screw that had been added over 30 years. The wood behind he reinforcement for the binnacle and steering wheel was rotten, so I took an angle grinder and tore out all the bad wood. I will replace that with some marine plywood. I went and got some high density foam to get to work on covering all the other holes, and there are many.
                Clearwater, FL
                  wow buddy good to see you back on here. you use to roll with the 238? I believe i had you on the classic mako calendar on year. I enjoy the years of CM. havent been on much but would like to try to make an effort. looks like you got your work cut out for you. glad to see you used sunshine. they have ALWASY treated us well with the funaments
                    That was me, I still have that pic of my 238 sitting at the Bimini Big Game Club in Bimini on my wall. That boat is now owned by a nice European gentlemen who summers in Germany and winters in Tampa. Sunshine was more expensive than the other options, but they were the only option that fit exactly, so I was not going to quibble over a few dollars for a less than proper tank install. I have been working on the console now while I wait on the tank. I glassed in a piece of plywood for under the steering and binnacle, and am using foam to cover the numerous other holes.
                    Clearwater, FL
                      The console is just about ready for paint. The wife and I went down to Key West last weekend, (went six of eight on bonefish), and on the way we stopped by Sunshine Tanks in Medley and picked up the tank, which was ready. It went in the back of the wife's Lexus and now I should get it installed later this week.
ID:	548325 Click image for larger version
                      Clearwater, FL
                        new tank installed, all new hoses, new cover glassed and screwed in.
ID:	548384 Click image for larger version
                        Clearwater, FL
