mako 21 transom
  • #16
ID:	545522Click image for larger version
ID:	545523 got the inside layed up,total of 9 ply 1708,a little shy of a half inch ran out of epoxy again. back to it next weekend!
    ​​​​​​r
    • #17
ID:	546239 got the outer transom layed up 8 ply of 1708 2 ply of 24 oz rovin tabbed about 10 inches around and under hull
      • #18
ID:	546241Click image for larger version
ID:	546242framing for bracket mould
        • #19
ID:	546244 mould ready to go ,most of my shell glass all cut, ran out of 1708 got more coming tomorrow and i should have outer shell all layed up this weekend,i dont know exactly but i think im in about 12 gallons of epoxy so far,im sure this bracket will take 5 more
          • #20
            Do you find it difficult to wet out the 1708 with epoxy? Or are you using a stitched mat?
            • #21
              it is a stitched mat,but if your starting dry it takes a bit to get it wet but once you get the first layer wet the rest went good
              • #22
                also depends on what epoxy you are using
                • #23
                  You have a preference/easier-thinner epoxy that works better for that?
                  • #24
                    ive been using total boat 5 to 1 epoxy,works great
                    • #25
ID:	546332Click image for larger version
ID:	546333Click image for larger version
ID:	546334Click image for larger version
ID:	546335 got the bracket layed up and 1 sheet of ply
                      • #26
                        Amazing work. Can’t wait to see more updates. I have the same hull and will need to address the transom soon. Thanks for sharing your progress.
                        • #27
                          Thanks , back at it tomorrow weather permitting
                          • #28
ID:	546489Click image for larger version
ID:	546490Click image for larger version
ID:	546491 cut opening for stringers also took off bracket mould and trimmed,forgot to take pics
