1992 Mako 261B "Reel Impressive"
  • #76
    How hard is it to drill through the Arjay?
    Gautier, MS[br]1977 Mako 17 135 Etec HO[br]1987 Mako 261[br][br]http://classicmako.com/forum/topic.asp?TOPIC_ID=52148&whichpage=1
    • #77
      Harder than wood, easier than steal, probably like aluminum or a softer metal.
      • #78
        Sanding on the other hand..... that stuff itches like nothing else I've done on a boat.
        • #79
          Did you remove and seal up all the penetrations in the transom before pouring it? From what I can see in the picture you left the 3 drains at the bottom in place?
          • #80
            The transom does not go down that far on the bracketed models.
            • #81
              Stroken,
              Being that you have done a 261 and 261B could you please tell me if the 261 (200 gal)fuel tank will fit in a 261B (185 gal). I have a tank from a 261 I rebuilt and my buddy bought the 261B from Castrohasanafro and it has a bad tank in it. If we replicate the larger tank can it fit in the 261B without mods to the liner?
              My 261 tank has a tapper to the height starting at roughly 14" tall and growing to 16" tall. We do not want to derig his 261B till a tank is ready.
              Miss Grace[br]Mako 261 of a kind[br]Anydayonaboat.com[br]Cracker Boatworks[br]
              • #82
                The 261B has a 203 Gallon tank in it .
                • #83
                  Originally posted by lmariotti
                  Stroken,
                  Sorry for such late reply, but I believe they are the same tank, 200 gallons
                  • #84
                    It’s seems like it has been forever, probably because it has. But slowly chipping away on this boat. I filled in all the drain channels, so had to come up with a drainage system for the front fish box. I came up with this 1/2” pvc drain system for the front hatch. I also put floor drains in the two side boxes in the U seating that will tie into the back side t that isn’t complete. I have a piece of 3” PVC ripped in half running down the center of the boat to the bilge area that I will tie all of my drains into.
                    • #85
                      Wahoo! It does still exist. I hope the work continues and we don't have to wait another 3 years for an update.
