2002 Mako 314 Fuel Tanks
  • 2002 Mako 314 Fuel Tanks
    Labor Day Weekend'19 I started the fuel tank removal from my Mako 314. One or both of the 150 gallon tanks were leaking gas into the bilge. I plan to outline the tank removal process I went through and the custom design and installation of replacement of the tanks.
    BackInBlack[br]Charlestown RI
Name:	1 Leaning Post Port Side.jpg
ID:	540610Click image for larger version
Name:	3 Leaing Post Removed.jpg
ID:	540611Click image for larger version
Name:	2 Leaning Post Port Side.jpg
ID:	540612 Port Tank removal was a B****! In total it took 5 days...
Name:	4 Port Deck Cut & Removal.jpg
ID:	540614Click image for larger version
Name:	6 Port Tank Filler & Vent.jpg
ID:	540615Click image for larger version
Name:	5 Port 150 gal tank exposed.jpg
Name:	9 Removal Attempt #2.jpg
ID:	540619Click image for larger version
Name:	8 Removal Attempt #1.jpg
ID:	540620Click image for larger version
Name:	7 Port Tank Sending Unit and Supply.jpg
Name:	10 Removal Attempt #2.jpg
ID:	540624Click image for larger version
Name:	11 B-2000 Resin Cleaner.jpg
ID:	540623Click image for larger version
Name:	12 20 Ton House Jack.jpg
Name:	13 20 Ton House Jack.jpg
ID:	540627Click image for larger version
Name:	14 Holes Drilled.jpg
ID:	540629Click image for larger version
Name:	15 Holes Drilled.jpg
Name:	16 Tank Cut.jpg
ID:	540631Click image for larger version
Name:	17 Tank Top Removed.jpg
ID:	540633Click image for larger version
Name:	18 Baffles Cut & Removed.jpg
Name:	19 Front Tank Lift.jpg
ID:	540636Click image for larger version
Name:	20 Tank Stuck.jpg
ID:	540635Click image for larger version
Name:	21 Tank Cut in Half.jpg
Name:	22 Tank Removed.jpg
ID:	540640Click image for larger version
Name:	23 Tank Coffin.jpg
ID:	540641Click image for larger version
Name:	24 Tank Coffin Cleaned Up.jpg
                    The reality is that FOAMED in tanks do not want to come out easily. They also trap moisture between the aluminum tanks causing crevice corrosion and fuel leakage. The secret to the removal is FGCI's B2000 Resin Cleaner Here is the link: https://www.fgci.com/item/139080/B-2...leaner-1Gl-Cn/ It will dissolve the foam and break the barrier around the tank on the bottom and at the stringers. The instructions do not recommend how much to use or how long to wait. At first I ordered one gallon at a time and then a 5 gallon container for the Starboard tank. It was a wait and see procedure that took 5 days on the Port tank. I slowly poured the B2000 around the perimeter of the tank and dug out as much dissolved foam as I could. Quite the mess. In retrospect, I would have dumped several gallons around the tank, waited 24 hours and then removed the tank. This is what ti did on the Starboard tank. Two days vs. Five days removal time! In both cases the tanks were drained and then filled with fresh water and a small bottle of Dawn soup. I felt safer drilling holes and cutting apart the tanks this way. Hydraulic jacks were required to break free the tanks and lift the tank parts free from the hull.
                    Custom tanks have been designed and will installed in spring'20.
                      I have a 313 (Express version of your rig). I hope to never have to tackle this task on mine, but appreciate your documentation of your adventures.
                        Tank update. Two custom tank designs have been submitted and drawings approved. New tanks were based off original 150 gallons (each) design but downsized in order to ease installation. The gunnels would have to be removed to install original size tanks. New tanks are 115 gallons (each) based on my spec's to a marine fabricator Luther's Welding in Bristol RI. Attached are several pic's of the Port fuel tank and the drawing of the new design. I hope to have them installed before the summer. Once decks are installed I plan to install custom SeaDek embossed decking, coaming polsters and helm pad.
Name:	Port Tank 1.jpg
ID:	544664Click image for larger version
Name:	Port Tank 2.jpg
Name:	Port Tank 4.jpg
ID:	544666Click image for larger version
Name:	Port Tank 5.jpg
Name:	Mako 314 New Tank Design.png
