1970 19"6' rebuild
  • #16
    1970 19\' Mako[br]1985 15\' Chaparral Deluxe 162[br]
    • #17
      Dry fitting transom. I went with two 3/4 in marine grade plywood sheets
      • #18
        • #19
          • #20
            Doing a dry fit before glossing everything
            • #21
              Bonded both plywood sheets together with a layer of 1.5 csm and 1708, once cured I came back the next day and glassed it to the hull with a layer of 1.5 csm and a layer of 1708 and I used bonding putty as well so it would fill any voids. I also double tabes with 1708. Let this set for two days and glassed inner portion of transom with 1 layer of 1.5 csm and two layers of 1708 and bouble tabbed
              • #22
                • #23
                  • #24
                    • #25
                      • #26
                        • #27
                          After installing the transom, I ripped out all of the stringers. Laid 1 layer of 1.5 csm then a layer of 1708 going from left to right. Then I laid another layer Of 1708 from front to back. Stringers are 2in Carbon core honeycomb, I bonded them to the hull with light weight bonding putting I picked up from fgci.
                          • #28
                            • #29
                              After bonding the stringers to the hull I removed the cap and sanded the hull sides and laid down one layer of 1.5oz csm and a layer of 1708. Next, I will be using bonding putty to bond 1/4 devinycell foam core to the hull sides and afterwards I will lay another layer of 1708 and a layer of 1.5oz csm to finish the hull sides. Will post pics of the completed job.
                              • #30
