1988 171 Mako fuel guage inoperative
  • 1988 171 Mako fuel guage inoperative
    The fuel guage has not worked since I purchased the boat 18 mos ago.Where do I start?(any tips would be appreciated)
    If I am correct to assume it is the manual gauge under the console coming out of the top of the tank? If so, the gauge is magnetically operated. The dial on top is all that needs to be replaced. Removes with a couple of screws.
    Boat Owners Warehouse 1-800-boats-99 had the replacement dial, but you will need it out and in your hand to give them the information on the dial.
    Good Luck!
    Bill
    Bill Moore[br]Eden, North Carolina[br]\'81 Mako 21 Center Console
      check the connections to make sure the fuse is not blown, they wires are plugged in and aren't corroded. Many electrical problems can be fixed just by taking the connections off and cleaning them.
        If it is an electric guage go here; http://www.tflx.com/tech.html
          Thank you Sailor...I will definitelly give this a try first.
            Thanks Warthog5...that is a great site for trouble shooting tips.
              Here's how to get the gauge - see my post at the bottom of this discussion http://www.classicmako.com/forum/top...rms=fuel,guage
