help removing protective film on windshield
  • help removing protective film on windshield
    I just bought a windshield and the protective paper will not peel off very easily at all. Is there any safe adhesive remover or anything that will not damage the windshield. Thanks
    Try a warm blow dryer (NOT HEATGUN NO..NO..NO). The protective paper is a bit like masking tape with its adhesive. If you warm it gently it peels easier. Clean the residue with alcohol. If it is plexiglas or other plastic-based materials (other than glass) don't use acetone or nail polish remover as it will disolve the outer layer of plastic and haze the glass.
    -Pat.
        Thanks cyclops I'll try that. RingLeader I'm talking about the paper that comes on plexiglass or lexan when it is new to protect it. The windshield I bought had been sitting in a garage for twenty years (1984) so the paper is pretty stuck. Please help!!
          Gotcha. I thought the rabbit pix was pretty cute and had to work it into some thread and you were the lucky one. Sorry.
          I'd say to stay away from tough solvents. Usually the stuff just peels right off, but I'm guessing that age is a big factor here. Its probably carmelized so to say. I'd try goof off or mineral spirits on a very small area first. Somewhere out of view. I wouldn't do any scraping with sharp tools... this is gonna be a fingernail job.
          If that doesn't work... Refer to the pix above.[]
            For some reason the damn bunny gave me a big laugh!
            1975 23\' Tampa,FL
              I've been laughing at it for 2 days now. Every time I see it! Kristie, said, "it's cute and all, but I don't get it?"
              Best sense I can make of it is that your just not supposed to get it. He's a cute little wabbit with a flapjack on his head.. Speaking of which... I'm walking out the door to hit the Waffle House right now!
                Don't expect them to get it
                1975 23\' Tampa,FL
                  still struggling with it !!!!
                    Miguel, I have had similar problems and have had good luck using warm soapy (kitchen soap)water.
                    Mike[br]S.E. Ma[br]
                      DAMNIT!! WISH I HAD A WAFFLE HOUSE IN MY FRONT YARD!!![]
                        Olive oil works. Finally making some progress.
                          You could also find a local shop that sells windshields and or materials and either call or stop by to see what they have to say about removing the paper. Being that's their business, they probably have already run into this and could have a simple easy way to do the job.
