My fill hose is too short...
  • My fill hose is too short...
    they read the wrong measurement and welded the fill tube 3 inches further into the tank... can I use a connector piece of pipe to lengthen the hose??
    Jake the answer is yes, but I don't like the idea of not being able to check the conections. You will be creating another chance to have a leak.
    I would suggest that you coat the hose with some Peremetex #1 on the inside when you make the hook up.
    We don't need to have a leak that you can't find.
      thats for sure... this is the third time in 1 year that Ive had the deck/console off the boat! My '72 now has a new tank, new hoses,new wiring, new hydraulic steering, a new/leftover 2000 J225 and some new fiberglass on the deck. Hopefully no problems for a little while[]
        thanks for the advice warthog!!
          Jake, who's they? Try getting them to fix it.
          \'81 21\' CC Mako[br]Beaufort, NC
            I agree, it sounds like it was their mistake. You paid for a custom tank and really didn't get what you paid for. They should correct it.
            1975 23\' Tampa,FL
              I'll call them monday, Atlantic Coastal Welding, Bayville N.J.
                If the fill hose connection is 3" too far into the tank, wouldn't that cause a problem for filling it? If I had to guess, you'll have to slow the gas flow way down to top it off.
                -Pat.
                  The fill elbow itself is 3 inches too far towards the center of the tank.
                    They made the mistake...let them fix it. At the very least they should buy you a new fill hose so you don't have to piece it together.
                    Brian[br]St. Leonard, MD
