live well on 94 mako 171
  • live well on 94 mako 171
    I have a 94 mako 171 and I was wondering exactly how the live well works. does it take in water from the outside or just recirculate the water that's in it? Also, if it takes it in from outside, where should I look for the water intake, etc.?
    Thanks,
    Wolfram in Corpus
    I can tell you this much, if it is simply recirculating the water, your bait will not last long.
    You probably need to figure this out for your self. find the pump and trace the tubes see if one goes to a place on the outside of the hull. If it does then it is picking up fresh water. if the thing just makes a loop then it is recirculating.
    The other thing is does it simply fill when you launch the boat or does it only fill when you run or turn on the pump?
    This will probably just take some investigation on your part
    1975 23\' Tampa,FL
      Wilson,
      Thanks for restating my questions. Does anyone have a 171 cc with the live well in front of the console that knows how it works?
      Thanks,
      Wolfram
