1979 Mako 21
  • 1979 Mako 21
    I have recently bought a 79 21 foot Mako in good shape with a 90 Johnson 200 which I am told by the owner needs work (low compression and weak tilt). I have decided to go low tech and replace the 200 with a new 175 Johnson so that I can do maintenance myself and have access to a good dealer in my area. Are there any issues with this vintage 21 I should be careful of and does anyone have any thoughts on a better repowering plan? Any comment would be appreciated. She's abeauty and I want her to be right when done.
    Can't comment in regard to your vintage hull, but in regard to repowering with a 175, I think you might be under powering it. Does it have a T TOP? What type of weight will you be carrying etc? I presently have a 200 on my 21 and I am not real happy with the performance. My plan is to install trim tabs in hopes that cruise and WOT performance improves. If that doesn't help I am going to step up to at least 225HP. Maybe somoene with a 175 can jump in here and comment further.
    Ron
    1993 Mako211CC
    200 Black box
      I must agree about the power. I went to a from a 200 to a 225 on my '78 21 and it was a night and day difference. Rigged with a ttop and crow's nest the 225 made it comfortable to fish 3 guys and all the gear. The hull? no complaints at all. Large trimtabs made it awesome. We fished it 50 miles from shore regularly:
      She's gone now, making someone else happy...
        PeteH
        Do you have any idea what your performance numbers were with your 200 vs what they are now with your 225?
        I am running @ 4200 RPM to cruise at 24/25 mph and WOT is 33/34 MPH @ 5600 PRM. Those are GPS numbers. That is with 2 people and 60/70 gallons of fuel. I a turning a 4 blade SS 17 degree prop.
        Ron
        1993 Mako211CC
        200 Black box
          I too had a Yamaha V6 Excel (which is about 200 hp) on my Mako 21. It was miserable. I had very poor hole shot, even with an empty boat. Trying to pull water skiers was a pain. Fuel economy was horrible because I was always trying to make at least 30mph. When I had 3 guys in the boat + gear, the boat was even worse. I just didn't have the power to run comfortably for me and the motor.
          I was running a 16"Pitch wheel and WOT was around 5400rpm at 40 mph (unloaded). I went to the 225 EFI Merc. and She runs the almost the same reguardless of load. With a light load I can turn up 5700rpm at 50mph.
          I'm all for max power on these heavy boats. In fact there is a fellow Mako 211 owner on this board who has a 250 Merc. He told me he'll never go back to even the 225!
            I wish I hade a 225 but I'm still happy with the 200. 3 Guys 170 to 200 lbs ea. w/ beer, ice, food, and gear on fresh water I was getting 42 MPH at 5600 RPM on the GPS. That's with a 15 1/4 ( I think) X 19 pitch alum. prop. The engine in mounted 1 hole up from the max depth. This was done to stop ventilating and over reving. Pulling a skier up on 1 was a non issue with 3 others on the boat.
            1985 Mako 21 B 2003 200 HP Mercury SW Classic
              Mist..
              Do you have a T TOP on your boat and how much fuel do you have on board?
              Ron
              1993 Mako 211CC
              200 Black Box
                One things for sure... Mercs have bigger kajonees than any other motor. A 200 Merc is about as strong as a 225 in any other brand[:0][:0]
                  Live Bait, No T top[]. The bottom really needs a stripping and a fresh start if any paint at all. The longest the boat sits is 3 to 4 weeks in VERY cold fresh water. Other that that it's trailered around. The Mako 21 B holds 86 gallons.
                    Can't imagine smaller than 225. Have 1988 21B (21'7"). Cruise @ 4600 RPM 28-30 MPH, 12 GPH. WOT 6100 @ 42 MPH. OMC SST 21 Prop.
                    A new direct inject 200 might fill the bill.
                      Charles, I have 1980 215 with '92 225 Evinrude and I am very happy with the performance. I have a 19" stainless prop which also aids the performance. 4200rpm = approx 30mph. Go with the biggest allowable power it also enhances the resale value. Too many underpowered boats out there.
                        The 200 Johnson on my 76 221 gave me up to 46mph on the GPS. I dont recall what the RPM's were, but she was screamin pretty good. I tried not to run her that hard as the motor had quite a hours on her before she let a cylinder go last October. I have to take a look at the prop, been so long since I ran the thing. Hopefully by the spring I will have her back together and chasing stripers again.
                        Greenwich, NJ[br]1976 22B
                          Loaded with 110 gallons of fuel, livewell full of water, and an unbelievably heavy T-Top, I cruise 30 MPH @ 4200 RPM's.
                          2000 Suzuki 225
                          87 21B
                          Prop Pitch & Diameter unknown.
                          Aren't these hulls rated 230hp?
                            I ran a 1989 200 yami with a 17p yami wheel originally. I had the wheel beat down to a 16p to get the 5500 rpms. She ran @40mph. Then I put a 250 yami on turning a 19p. 45mph at 5500. Final engine was the 225 with the same 19p. 47 mph @5500. All the props were the old style yami stainless. I tried a number of different props but those yamis gave the best overall performance. BTW the engines were mounted as high as they would go...
