Help...anyone have advice on rust stains??
  • Help...anyone have advice on rust stains??
    The "master boat builder" that owned my 25 cc before me had a thing for sheetrock screws. I would like these rust stains to disappear and David Copperfield is booked up. I have heard everything under the sun, but people in these forums seem to know what they are talking about.....thanks
    try some rubbing compound
    Prev Boats[br]1974 18ft Fleetcraft 74-97[br]1974 20ft Mako 95-99[br]Currently[br]1978 25ft Mako CC 99-??
      oxolic (sp?) acid....try those little plastic cans of blue jelly called 'FSR' - 'Fiberglass Stain Remover', or 'The Works' toilet bowl cleaner. Will pull them right out, just apply, let it sit for a few minutes and rinse before it dries.
        fsr is the stuff
          The stuff at the grocery store called.....rust stain remover....be sure to rinse well.
            cheapest way is to buy oxalic acid, its a weak bleaching acid and is also an iron scavenger other than that try any of the boat care products ie davis fsr, rule fiberglass stain remover etc
              Sno Bol toilet cleaner
              1975 23\' Tampa,FL
                Carpetdiem-
                If those products that others have recommended dont work.....Take some wet/dry sandpaper on a block...around 1000grit and try to gently wetsand them out of the gelcoat. If the 1000 doesnt work, move down to 600. Just be careful not to sand through the gelcoat.
                Ed
                  thank all of you for the advice....I have my work cut out for me
                    The absolute best is On&Off hull and deck cleaner. Not only will it take care of the rust it will make childs play out of any water stain
                    you can get it a most marine stores. Go ahead and sieze the day and get some
                    Matthew
                    Gulfport,MS
                      Mary Kate On/Off is an acid sold at most Boating stores. You may have to treat it several times to remove heavy rust stains.
