What is your favorite trailer tire
  • What is your favorite trailer tire
    Since I am going to Florida and back this June...it would probably be a good idea to replace the BAIS tires on my trailer[]...piece of mind!
    My current tires are 205/75/14....I can read reviews online all day, but talking with people who know is a much better response in my mind. When it comes to tires I tend to spend more out of shear fear! Any comments are welcome and thank you in advance!
    goodyear Marathons were always the top of the line trailer tire for years...Hopefully they are still as good. I usually buy the cheep ones and always have a spare...
    The good ones will last 4 years...and the cheep ones will only last 48 months....[]
      I had great performance from the dreaded carlisle's, but I had them balanced before installing, maintained air pressure before every trip and put tire covers on them when not in use, plus I parked them on a concrete pad. Before that I had a set of goodyear marathons that let go in spectacular fashion twice. IMO balancing them and maintaining air pressure is far more important then brand.
        I also have been very happy with the Carlisle tires. I'm running size 7.00-15 LT.
        There is nothing wrong with running bias tires on a trailer. They don't sway as much as radials. On a top heavy load such as ours I believe it is a good thing.
        Size them for the weight they will have to carry. Bigger is better and they will run cooler.
        Ole Joe
        Just floundering around
        Shrewsbury, Pennsylvania
        1978 Mako 25, Sold
          I agree with Sailor & have mine balanced as well. I was told that the rims were/are not made
          to the close tolerances that your cars are made to & that balancing is a waste of money. Money well wasted IMO.
            Most important is to purchase the correct load rating for your boat. These old Makos are heavy girls. We purchased new rims and tires this year because we're going to trailer rather than wet slip like we've done in previous years. I've hear that radials side walls are more flexible than Bias too. Load rating of at least "D" should suffice.
            Keyman[br]Paoli, PA
              I have not had good luck with the loadstar tires, which do not have very good highway tread pattern..more like offroad tires than drag behind the truck and roll easy tires. I replaced them with a set of supercargo tires from a local guy..nice straight grooves. Although I noticed that the sidewall is starting to alligator up in the tread even though I keep them pressured up and coated with protectant. Gonna have to replace them before next winter.
                Where else can you get a wealth of real life experience like this! Thanks to all. I currently have 205/75/14 bias tires. My reading and research tells me that a 215/75R14 ST in Load "D" would put me a 2200lbs per tire tire or 8800pound of towing capability op to 81 mph...glad to hear that if youve seen my wife drive! I don't havea weight slip on my loaded 25, but I can't believe its close to 8800lbs?????????
                I have to check the added size from 205 to 215 but I think I have plenty. I am only choosing the radial because I want to eliminate heat going to the road to Florida. If I had room I would probably up to 15 inch rims.
                I am looking at theses which have a pretty great following: https://www.etrailer.com/p-TTWTRTM2157514D.html
                  I had marathons for years
                  I dont think theyre made anymore
                  Coleman D Brown[br]6554 Florida Boulevard[br]Suite 233[br]Baton Rouge, Louisiana 70806
                    I had a tire store mgr. tell me you can't balance trailer tires due to a difference in the rims from passenger tires. Didn't sound right to me. Agree with air pressure check, tire covers and concrete pads.
                      Balanced my share of tires and the machine has no idea what rim is on it.....I used to build engine and we would balance crankshafts in a very precise machine. I was always amazed what 1oz could do spinning at 5000rpms when you moved it out from the center. The pounds of force were AMAZING!
                      I balance everything.....just my $0.02
                        "the machine has no idea what rim is on it"
                        Wheel is centered on the trailer via lug bolts. It is centered on the balancing machine via the center hole. It was explained to me that the center hole is not as accurate on the cheap trailer rims as a car rim.
                        With that said - I still get them balanced. Never sat on the empty trailer at 60 mph to see if it made a difference. If anyone has - let me know.
                          I have balanced all of the tires on my trailers, especially in duals. I have had the unbalanced tires cause some weird vibrations on the way back and forth to florida from new jersey. It was annoying and after having the tires balanced, the trailer did not do it any longer.
                            ahhhhh
                            I use a "road force balancer" these actually load the rim with road force while spinning. You also can but them on a lugged hub instead of using the center. Additionally when I mount I use a runout gauge before tightening the lugs...
                            Belt and suspender kind of guy[] I agree with everything you say and thank you!
                              I recently put on a pair of Goodyear Endurance trailer tires, same size as yours. They're not cheap, but they're rated for 80mph. Won't be making a run to FL for a few months, but they pull very nicely so far on shorter trips. I've had some bad luck with cheaper tires I've tried, one too many blowouts and belts broken, so I got frustrated and spent the extra money. I'm only towing a flats boat, but I would think you'd get the same results with bigger Makos.
