Livewell Conversion Question
  • Livewell Conversion Question
    I have a 1978 211 and when my dad and I replaced the floor in it 10 years ago we got rid of the infloor livewell because the fishing we did then didnt need one. I have since moved to Florida and do a lot of bottom fishing in the Gulf and use live bait all the time. I currently use a 30 gallon creek bank bait tank in the front of the boat but it gets in the way and is a pain having to change the water out in it a couple of times a day. I was wondering if anyone has ever tried to convert the cooler seat up front into a livewell or other ways that anyone has made a livewell in their boat. Im not opposed to a leaning post livewell either but I havent been able to find one that would fit well in my boat. Any help is appreciated. Thanks
    David Clark[br]1978 211[br]Orlando, Fl
    No conversion here but a Moeller 26 gallon fit just right under the leaning post of my 20.
      Rule makes a pump bracket that mounts on transom. Run hose in to bottom of 30 or 50 gallon drum. Put a plastic thru hull at top of tank with 3 feet hose over side for overflow. Easy peasy and very effective.
        One of my fish boxes is a live well. Works great. There was one done on the site. It is pretty easy to do. Plumb in the live well pump and run a drain out the side of the fish box and hull. Use a plug in the drain.
          Thanks for the input. I hadnt thought about using the fish box as one. Now that I wont have an oil tank in it then it is open for whatever.
            I cut the boxes out and added a LP/Live-well. No regrets and would not add that much weight to one side of the boat. My LP came out of a mold that he is still using to produce them. Not cheap- completely outfitted is around 1700.
              Thanks Snapper. Is that from nautical design in PA? Ive been looking for a leaning post livewell but havent been able to find one that fits well with still having the boxes in the back but it looks like yours would work.
                It was designed custom to fit with boxes. Call me 386- four51 1053 if you want to chat about it
