Transducer tilt thru Hull. 20 degrees?
  • Transducer tilt thru Hull. 20 degrees?
    I am eliminating the live well vent thruhull and placing an airmar transducer thruhull in its place. Is it correct to say Id need a thruhull with 20 degree tilt? Going on a Mako 21.
    Get an angle finder, measure both sides at the mirror spot, add and divide by two and that's the angle of ducer you need.
    1975 Mako 26 Inboard[br]1976 Mako 23 Inboard[br]1984 Rhodes 19[br]Padanaram, MA
      Just verified...20 tilt is correct. Thanks.
        I put a 20 degree tilted element transducer in a 21B and it worked great and I did not have a large transducer under the hull to grow stuff....
