Been running my boat and overall happy with everything working. Of course I'm getting the itch to find something to do on it other than fish. This got me looking at my motor and prop setup and wondering if I had room to improve. Here are some basics of where I'm at today:
- Mako 20B
- Vent plate parallel with bottom mounted on 3rd hole
- 99 Johnson 150
- Prop is OMC PN 389924 which is a 3 blade 14.5x19
- WOT and trimmed for speed gives me 36.2 knots @ 6000 rpms
- Cruise before falling off plane is 22.5 knots @ 4000 rpms
Here are some things I'm wondering about
- After some research, it seems my WOT is about 500 rpm high. Before raising my motor, changing plugs, and running Seafoam, I was getting 5000 rpms with this setup. With this setup, trimming for speed I can get to 6000 before dropping speed, but should I focus on trimming for RPM? Is this reason enough to reprop?
- Working through the prop slip calculators, it seems I'm getting a 28% prop slip which seems high. I ran the WOT numbers for Sailor's old one which seemed the closest to mine and it looked like 24%. Is this still a gremlin to chase down or a likely characteristic of the 20?
- Falling off plane at 4000 rpm and 22.5 knots seems high to me. I have no real numbers to back this up, but have noticed that there have been several times where if I could run a bit slower while staying on plane, my ride would be much better. Is this a prop issue or a sign that I want trim tabs?
- Mako 20B
- 99 Johnson 150
