Cant see images anymore
  • Cant see images anymore
    When I open any of your posts I see a split second of the posts images then they show up as small squares. I think its because of some software I installed last year to be able to see the photobucket images of the past. The software patch was posted here on classic mako. Has any one else had this issue and is there a way to fix it?? thanks
    I am having the same exact issue. I did the same with installing the "patch" which worked for months, but now I see the image for a split second and then the images show up as small squares.
      I was having the same issue. I actually turned the patch off and it seemed to work.
      1973 Mako 19[br]
        The "patch" is causing the issue as it is redirecting off of photobucket from their SNAFU. You can turn it off or use a different browser to see the images.
        If a user deleted their images after the patch was released and they only reside on the "patch server", then the only way to see them is to have the patch turned on. This mainly impacts older posts.
        Hopefully one day we can get an upgrade back on the front burner.
          You have to undo the fix. Look in the upper right of your browser screen, find the icon that is a down arrow (in chrome) or the icon that allows you to manage extensions, right click on it, click on manage extensions, turn off the one that is photobucket redirect.
          David, New Kent, Va[br]
            Thanks guys...David B you were spot on.... I can see clearly now...
            d
              Turning it off worked for me. Thanks!
                [8D]
                d
