starboard__question
  • starboard__question
    hello all does anyone know the name of that "beige" colored starboard that mako used to replace teak and where to get some thanks
    Elizabeth King
    Boat outfitters has a color called seafoam that matches makos pretty good.
    Episode Twelve, Season OneThe crew at MCU wraps up the final rigging on the classic 22 Mako restoration; FS Boating Editor Dave East heads out with Brian O’D...
    Jake Dodge - Maysville, GA
    1985 Mako 171 “T/T Broken Arrow”
    Project Thread: https://forum.classicmako.com/forum/...171#post559680
      You might be referring to the "Fish White" shade on the Starboard color chart.
      See more info here....
      King Starboard is the leading marine-grade plastic sheet material you can trust. It’s UV and moisture, meaning these starboard plastic sheets will never fade!
      Eric
      1972 Classic Mako 19
        thanks guys I will check those out i think I may be slightly color blind
        Elizabeth King
          Seafoam is almost an exact match to mako gelcoat. I replaced some of the hatches on my old 231 with seafoam starboard and couldnt have been happier with the results. Pictures of the hatches I made may still be in my 231 restoration thread unless photobucket took them down. The only downfall is that it is slippery when wet so keep that in mind if youre going to use it anywhere you may be walking.
            PoleLock--those are just the ones that BoatOutfitters seems to sell.
            See the full list on the King Starboard website, in the Colors "+" tab:
            King StarBoard® The Original Marine Grade High-Density Polyethylene Building Sheet
            On my own boat, FWIW, and on the pieces I got from Buck Plastics, the "Sanshade" color was used. See my boat pics in the link in my sig below.
            As for getting some, your local plastics guy, or sign manufacturer, should be able to order you a sheet of whatever you need. I recommend the 3/4" thickness, FWIW. Thick enough to round over the edges, strong enough, does not look cheap.
                Rogerjack2 Posted - 08/01/2018 : 18:20:56
                Haaa...I'm in the same boat...eye doc said I suffer from the most common color blindness, having trouble seeing red and green colors. I guess that's why my wife never lets me pick the paint or carpet colors [B)] []
                Perhaps you could get a sample kit to make sure you get the color you perfer.
                231Mike Posted - 08/01/2018 : 21:50:58
                I always thought that "Seafoam" color was a very light green???
                gmcauliffe Posted - 08/01/2018 : 22:08:52
                You are correct...the King Starboard website offers even more color options...I would certainly call them and see if samples are available.
                Eric
