[img][/img]Not having a seacock or ball valve on the 1 1/2" baitwell drain bothers me. The thru hull is barbed. My guess is to change the plastic thru hull to a bronze one and add a valve to it then connect the hose to a barbed fitting screwed into the valve. Is this correct? Has anyone done this to their transom thru hull and if so, what components did you use? TIA
edited to change hose size from 1 1/8 to 1 1/2.
